Fan Assisted Water Heater Power Requirements
Old 05-20-14, 03:47 AM
Typically what are the power requirements for a gas water heater with a inducer fan that exhausts thru PVC? Do they need a dedicated circuit?
Old 05-20-14, 04:36 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Yes they should have a dedicated circuit...
Old 05-20-14, 07:00 AM
Tolyn Ironhand's Avatar
Received 879 Upvotes on 742 Posts
Looking at my W/H the fan motor draws 5 amps. That is not 50% of a circuit, so according to the NEC, it does not need a dedicated circuit.
You can put it on one if you choose, but IMO it is a waste of a circuit space.
Old 05-20-14, 07:29 AM
lawrosa's Avatar
Super Moderator
Page #12 item line #1..
| A. O. Smith Water Heaters
Its not the power draw why a dedicated circuit, Its the sensitive gas valve that some line circuits can cause interference. Such as a line with florescent lighting, or what not...
Then the unit gets plagued by trouble codes...
Old 05-20-14, 07:36 AM
Mine is not that fancy. I guess it pays to buy crap. (Although my has been trouble free so far)
I still feel it is a waste of a circuit, like putting a refrigerator on a dedicated circuit, but you are required to follow the manufactures requirements.
BTW - its page 13.
