need help with lightswitch
Old 05-21-14, 06:21 PM
T
I think the light switch in my kitchen has gone out. It operates the ceiling fan and attached light. One day I flipped the switch and nothing. I have tried to change the switch but it is still not working. I went out and bought a new ceiling fan as well and still nothing. I was not smart and did not write down how the wires connected to the switch. So here is my question, how should the switch be wired. There are 3 wires, 1 red, 1 white and 1 black. The switch has one green screw on the left and two gold on the right. What wire should go where? Also someone told me that I should cut the exposed wire off and expose a new section, is this true?
Please help!
Thank you
Old 05-21-14, 06:34 PM
ray2047's Avatar
You have told us only half the circuit. What is the wiring at the fan?
Old 05-22-14, 08:30 AM
P
Received 2,228 Upvotes on 1,988 Posts
Is there another switch that also controlled the ceiling fan, like next to another door entering the kitchen? With those wires you've either got a three way circuit (two switches control the fan/light) or you have two switches, one controls the fan and the other the light.
Old 05-22-14, 06:35 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
You were not smart for replacing the switch and buying a new ceiling fan before troubleshooting the problem which easily could be something else entirely.
