Reload this Page >
Wiring a range (inbuilt oven and cooktop) in place of separate wall oven and coo
Old 05-27-14, 03:27 PM
N
Hello friends, Need your suggestion here.renovating my kitchen and replaced my old cooktop and wall oven with a new kenmore electric range.I have 2 separate circuits coming from the breaker panel (with 30A breakers on each).Now i need to wire my new range(sears.ca item no. 223 650 373 10).Now my question is can i join the same live wires from the 2 old circuits (each for old cooktop and wall oven) to divide the load equally on both circuits? As this range is going to take more amps so i need thicker conductor too.i got 10 gauge wires on both circuits but i think i would need 8 gauge wires for this new range.So would it serve my purpose?thanks
Old 05-27-14, 03:30 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You need a new cable run for the larger circuits. The current cables are too small to parallel under the electric code.
Old 05-27-14, 03:43 PM
N
thanks pcboss for the reply.what size of wire you would suggest for the electric range?
Old 05-27-14, 04:03 PM
pcboss's Avatar
The NEC would call for #8 for a 40 amp circuit. I do not have access to the CEC to check.
Old 05-27-14, 04:11 PM
N
yes thats what (#8 )home depot suggested.So if i combine 2 #10 wires for each live,wouldn't be enough.
Old 05-27-14, 05:14 PM
Received 1 Upvote on 1 Post
It's not that it wouldn't be enough, it's that you are not allowed to parallel two cable runs like that unless every conductor is rated to handle the full load on its own (which #10 can not safely handle 40A). If one of the wires were to break, the other would not be able to handle the full current of the circuit (and it would become 'overfused'), and the wire would overheat and start a fire. There's only certain situations where paralleling is allowed, and this is not one of them. You can only parallel to reduce voltage drop. You can NOT parallel to increase ampacity.
Old 05-27-14, 05:22 PM
N
Oh ok.now got it.thanks for the explanation. Time to run new wire..thanks again..
