Breaker keeps tripping, please help!!
Old 05-28-14, 12:11 PM
I live in the desert and it is very hot....been runnning my swamp cooler with no problem. Today turn on the water pump and the breaker trips. The fan runs no problem. I can't figure out why the water pump keeps tripping the breaker.
Any help is appreciated before I melt!! Thank you!!!
Old 05-28-14, 12:27 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Sounds like a bad pump. Is the shaft spinning freely? (Disclaimer: Never worked on an swamp cooler.) Do you have a clamp on ampmeter?
Old 05-28-14, 12:33 PM
As soon as I hit the button to start the pump the breaker trips. The shaft in water pump turns fine.
Old 05-28-14, 12:49 PM
pcboss's Avatar
Received 33 Votes on 28 Posts
Is the pump on a dedicated circuit?
Old 05-28-14, 12:54 PM
Received 408 Votes on 384 Posts
Most swamp coolers are very basic and plug into the wall. A blower fan, sometimes a media movement motor and a small recirculating type pump. It sounds like the motor windings may have shorted.
Old 05-28-14, 12:57 PM
Yeah, it must be the pump....it isn't that old, they only cost $25 - $30 so guess I need a new one.
