1 awg aluminum for a 200amp service
Old 05-28-14, 01:00 PM
H
Can 1 awg direct burial aluminum wire be used for a 200amp service at 65 meters in length? My electrician told me it would be okay so long as it is not encased in conduit so as to reduce heat build up. However, there is conduit from the footing to the meter base. Currently the electrical code in Canada states that you can have 135amp service with aluminum 1awg encased in conduit.
I just want to make sure that this service is not compromised.
Thanks
Old 05-28-14, 03:24 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
If you plan on using USE and Al. According to the 2014 NEC the conductor size should be 250 kcmil.
Geo
Old 05-28-14, 03:29 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
#1 AL is not large enough under the NEC, I doubt that it would meet the CEC due to the similar requirements between the two codes.
Old 06-02-14, 05:21 PM
spark4short's Avatar
wire size
U need to get another electrician before he causes some damage. Call building deparment if necessary. they always glad to help. Always put wire in a conduit in case of future problems.3/0 copper or 4/0 aluminum is minimum for 200 amp service on a residence.
Old 06-03-14, 05:58 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The NEC allows either 2/0 copper or 4/0 aluminum for a residential 200 amp service.
