Wiring two motion sensors in parallel?
Old 05-30-14, 12:24 PM
B
Can two motion sensors be wired in parallel?
I want to mount a motion sensor on each side of a garage to activate the same set of floods.
Yes, I know these use solid-state switches and not hard switches.
I just want to be sure current will not back-flow from one to the other.
I don't like fires.
Old 05-30-14, 12:27 PM
Received 1 Upvote on 1 Post
I've seen it done before with standard 3-wire motion heads.. Whether or not it was sanctioned by the manufacturer I don't know. However I can tell you there ARE motion detectors out there with a 'slave' wire - sort of like the interconnect wire on AC smoke detectors.. So when one detects motion, any interconnected fixture turns on.
Old 05-30-14, 04:32 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Your plan should work as long as the heads have three wires (normally black, white, and red for the switch leg) and they are the same circuit.
