Outlet from switch to half aways on
Old 05-31-14, 01:36 PM
W
In my apartment there is a switch with a black and red wire. The outlet has 3 conduits, see diagram. I want to make the top of the outlet work on the switch and the bottom be on all the time.
Do I just add an additional black wire to the 3 black wires and fun it to the terminal below the red wire, then break the tab connecting the hot terminals?
Old 05-31-14, 02:16 PM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
You diagram does not work. If the red is spliced to the whites you do not have a hot conductor.
Old 05-31-14, 02:52 PM
ray2047's Avatar
Unless you own the apartment for reasons of liability you should not touch the wiring. Ask your landlord to do it. Even if you own it local law may prevent an unlicensed person from doing work on a multiple residence building.
Old 05-31-14, 03:10 PM
W
I presume the red is hot coming off the switch. Supplying the outlet with power when the switch is on. Don't I just need to bring a black wire to other outlet after the metal tab is broken?
Old 05-31-14, 03:21 PM
pcboss's Avatar
Your diagram does not show a black at the receptacle to extend.
Old 05-31-14, 03:38 PM
W
Evertything except the switch in in the outlet box. So add a 4th black wire to the wire nut and connect it to the terminal below the red wire (hot from the switch).
Old 05-31-14, 04:08 PM
ray2047's Avatar
Here is what I would expect to see. Tell us how yours differs.
Old 05-31-14, 05:00 PM
W
No black wire above the red on the outlet and brass tab not removed.
Old 05-31-14, 05:08 PM
ray2047's Avatar
Does it look like this except for the second black I added?
Old 05-31-14, 06:20 PM
W
Looks more like your 1 st pic. The box with the switch has only one red and one black wire that go onto the outlet box. In addition there are 2 sets of white and back wires in the outlet box.
Old 05-31-14, 07:11 PM
ray2047's Avatar
Old 05-31-14, 08:36 PM
W
I adjusted your picture to represent the situation.
Old 05-31-14, 08:41 PM
W
oops ignore the extra black line thick I can't count there are 3 black wires connected to the wire nut.
Old 05-31-14, 08:47 PM
ray2047's Avatar
Yes what you propose is correct. Just be sure to remove the tab. Sorry for taking so long to understand you.
Old 06-07-14, 09:44 AM
W
Any idea why my tester says open neutral
