replaced GFCI-did I miss anything along the way?
Old 06-02-14, 10:50 AM
Received 1 Upvote on 1 Post
I plugged a lamp into a GFCI outlet, and ….nothing I checked the lamp in another plug, it worked. Back to the GFCI-pushed “reset”, “test”, “reset”… still nothing. I turned off the breaker and checked that all the connections looked good. I then removed the GFCI turned the power back on and checked for voltage with an analog multimeter. The meter read 118. Power off, I reattached the old GFCI …nothing. I replaced the GFCI with a new one, and all is well.
My question: As this was my first experience with a non-working GFCI receptacle, was there any other step/test that I should have done before deciding to replace it?
Thanks in advance.
Old 06-02-14, 11:42 AM
ray2047's Avatar
You did it correctly. Did all the tests and proceeded to the next logical step, replacing the GFCI.
Old 06-02-14, 12:16 PM
Thanks, Ray.
I followed what I thought were the proper steps- that I learned by reading items on this site. Glad that I didn't miss anything. Well done,Board! And thanks!
