Fusing down stream
Old 06-02-14, 03:40 PM
R
Fusing down stream
Hi I have a 460 v transformer with a load that goes directly to a fused disconnect not though a panel with a breaker. Is this to code or do I have to have a sub panel installed?
Old 06-02-14, 04:15 PM
ray2047's Avatar
Is the primary connected to a service panel? Do you mean you have transformer stepping up 240 to 480? Is it 3-phase? Can the device not be rewired for 240 eliminating the transformer?
Old 06-02-14, 05:59 PM
Tolyn Ironhand's Avatar
Received 862 Upvotes on 725 Posts
If I understand your setup, yes. it is OK because it is a fused disconnect. The fuses are your overcurrent device on the secondary of the transformer. Make sure everything is properly grounded.
