Madison Clips
Old 06-03-14, 11:24 AM
Madison Clips
http://www.doityourself.com/forum/el...son-clips.html
Will this type of clip work for a round ceiling box or is it meant for just rectangle wall boxes?
Old 06-03-14, 11:37 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Pretty sure they are for square only Jim.
Old 06-03-14, 01:56 PM
Received 3,419 Upvotes on 3,065 Posts
It's not really round or square.... round boxes don't have ears and will fall back into the wall/ceiling.
Old 06-03-14, 02:55 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Moved to own thread..........
Old 06-03-14, 04:16 PM
ray2047's Avatar
Should work.
Old 06-03-14, 04:19 PM
If you use that box and consider where the sheetrock ends...... the madison bars will cover over the wiring holes.
Old 06-03-14, 04:23 PM
ray2047's Avatar
Guess you'd have to put a Romex clamp in the knockout.
Old 06-03-14, 06:22 PM
Gunguy45's Avatar
Super Moderator
Why not just use an old work box I guess is the question? I used 4 in my garage, easy peasy.
Old 06-03-14, 06:44 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
Maybe and maybe not, what kind of fixture weight will be attached to it.
Old 06-03-14, 07:27 PM
ray2047's Avatar
They are pre old work box. An old DIY book of mine shows how to make them from tin cans. (but the tin plated steel in cans then was a thicker gauge then they usually use now).
