testing a compressor
Old 06-03-14, 05:28 PM
E
I have a wine refrigerator that has stopped working. I tried replacing the relay/starter, but that didn't help. I have a multimeter and want to test the compressor. The videos I find online all show compressors with three terminal pins arranged in a triangle. The one I have has only two terminals. Can anyone advise me on testing this type of compressor? Thanks
Old 06-03-14, 06:03 PM
Tolyn Ironhand's Avatar
Received 867 Upvotes on 730 Posts
Welcome to the forums!
It sounds like you are referring to a capacitor, not a compressor. Can you post a picture?
Old 06-03-14, 06:40 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Can you send a pic of what you are testing?
Geo
Old 06-03-14, 06:47 PM
Received 3,897 Upvotes on 3,494 Posts
Most wine coolers use PTC starting relays.
What make and model is the cooler ?
A pic or model number from compressor would also help.
http://www.doityourself.com/forum/el...-pictures.html
Old 06-27-14, 07:39 AM
E
thanks--i will post a pic and any identifying info i can find as soon as I can
Old 06-28-14, 11:02 AM
P
If the two terminals are motor-lead terminations , simply test for continuity across the terminals for a possible open motor winding.
Old 06-28-14, 03:51 PM
More than likley there would be three terminals.
C- common
R- run
S- start
