Adding double switch off an exisiting light switch
I want to know is it is possible to add an additional light and be on its own switch. I have it now on the same switch. I would like it separate if possible. Does the existing switch have to have power coming and going out? I want to be able to turn my closet light on/off without the room light. I only have power coming in to this existing switch.
Thanks for your help
now that I installed a GFCI in the bathroom and it trips it controls my bedroom.
You need to open the light up and document the connections BEFORE taking anything apart.
This house is old and has aluminum wiring that might the reason why it's wired that way. And you are right there is power coming in and then going to the bedroom. I am thinking on replacing all boxes and adding the alumicon connectors being that the old boxes are shallow and not enough room it was barely enough for that gfi
