5 rotary switch for AV cable
Received 0 Votes
I want to switch between 4 AV inputs (video only) and there are plenty of switches available. However, these are all very big so I decided to look if I can construct something myself.
I am thinking of getting 4 AV cables (the yellow part of the RCA cable) and cutting off the connector. As switch, I am thinking of using this:
2 Pole 5 Position Solder LUG 5 WAY Rotary Switch 2P5L | eBay
Bit before I start ordering stuff I am wondering if anyone knows if this would work and how to wire it up?
Welcome to the forums.
Yes.... that is a two pole five position switch and will work fine for your video only application. That looks to have 12 terminals around the circumference and 2 in the middle.
My diagram will go you some idea how to wire it. You would pick A or B and use the matching numbers. When you get that switch it will be numbered for you. Possibly like I've shown. If not, you could post a pic of the back of the switch and we could help you further.
Received 0 Votes
Cheers!
Am I correct in thinking that A (and it series) will be the positive and B (and it series) will be the negative. The centre A and B will be the output cable and A1/B1 will be camera 1, A2/B2 camera 2 etc?
No.... since you are using RCA type audio connections..... you will connect all the grounds together. The grounds don't connect to the switch..... only the center conductor. You will only be using half of the switch.
A little tough to show..... maybe this will help. Sorry for the crude diagram.
Now you're saying something a little different. Just using the yellow cable is video only.
With a dual RCA cable to a 3.5mm plug..... one cable is audio and one is video. They share a common ground.
