Ran out of knock out holes on the top of the panel
Old 06-11-14, 08:55 PM
Received 7 Upvotes on 6 Posts
I have an electric panel where the top side of it has about 10-12 knock out holes and they are all occupied (some EMT conduits some romex) and everything runs up to the attic then head to various locations.
I still have a number of spare slots for additional circuits but I don't have space up top for additional circuits to exit.
Is there an easy solution for this?
Thanks in advance.
Old 06-11-14, 09:14 PM
Received 3,982 Upvotes on 3,574 Posts
Normally the panel is mounted on a piece of wood. There are knockouts on all sides of the panel. Bring the wires down and in the sides or in the bottom.
Old 06-11-14, 09:35 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
How about mounting a trough above the panel? If you use a nipple 24'' or shorter you won't have to derate.
Old 06-12-14, 05:00 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Most NM clamps are listed for 2 xx-2 cables in the correct size.
