Junction box, would it pass
Received 0 Votes
I ran out of metal boxes at home and rather than run out to the store again, I used a plastic wall box. It is in between the floor beams in the basement.
Will this slide by when the city inspector comes at the end of all my work?
Or should I swap it out for a metal junction box before that time?
Thanks,
Thanks,
Received 0 Votes
Thank you pcboss,
I did not tack the wire down until I knew if the box would stay or have to go.
I will switch the cover for plastic, nail down the wire and move on. God knows there is still a lot to be done here.
Thanks!
Thanks!
