Tandem Breaker with Square D qoc-20m series e7
Old 06-14-14, 03:16 PM
T
Unhappy Tandem Breaker with Square D qoc-20m series e7
Anyway to use a tandem breaker with a Square D qoc-20m series e7 that is max'ed out?
No holes in the mounting bars so I cannot use the breakers with the hook on one side
if not does anyone have a workaround
Old 06-14-14, 04:33 PM
P
Temporarily Suspended
Would a sub panel work?
___________________
Old 06-14-14, 04:53 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Can you reposition another breaker? Not sure what holes you are referring to the breaker usually just snaps around a bar.
Geo
Old 06-14-14, 05:04 PM
Geochurchi's Avatar
How old is this panel? SQD has two styles of tandem ,one style has the handles side by side which needs a hole to install ,the other clips over the rail,check Ebay SQD OT2020 and you will see the difference.
Geo
Old 06-14-14, 05:13 PM
T
Looks like the SQD OT2020 *will* fit my box.
I cannot find a new SQD OT2020 breaker yet!
THANK YOU
Old 06-14-14, 05:21 PM
T
A sub panel would work, but I didn't want that expense just for one outlet for an AC and one ceiling fan on a dedicated breaker
Old 06-14-14, 06:18 PM
F
Do a Google for QOT2020 and lots of results.
Old 06-15-14, 06:09 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
It sounds as if you are wanting to install a non-CTL breaker in a CTL panel which would be a code violation unless your panel is a pre 1968 vintage.
