newbie: changing electric plug
Old 06-15-14, 05:05 AM
K
hi i am new to the forum and of course I don't have lots of knowledge about electricity.
I've recently bought a new air-conditionar which comes with 15A electric plug (circle in shape) See photo. But the socket available is only 13A which is rectangular in shape. Since I am not in the US or any other European countries , in case of confusion ,misunderstanding or different standards, I first post some photos of what I have.
13A electric plug bought from DIY shop.
Size:  28.9 KBName:  13A_plug.jpg
13A wall socket available. Our home doesnt have 15A socket.
15A electric plug that comes with the air-conditioner.
The shopkeeper suggested me changing the electric plug from circle to rectangular on my own to fit my wall socket. He commented that I can do it myself without having to look for certificate technicians, I only need to use a screwdriver and connect those earth wire, live wire etc. He claimed that's very very easy and he said if I want to change the socket, then I will have to find someone to help.
1. Is his word true?
2. What should I take of when it comes to changing electric plug
3. Do i have to consider the fuse or the power of the device.
4. I never done that before. In the worst case scenario, will it damage my device (air-conditioner)
Thank you.
Old 06-15-14, 05:56 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
The molded in 15 amp designation on the A/C plug tells you that that plug is rated for 15 amps. It does not necessarily means the A/C is 15 amp rated. You need to look at the lable on the A/C unit and see what the rated amps are listed as. The A/C label may also state the starting amp rating which will be higher than the running amp rating. Your wiring or outlet is rated at 13 amps so that means that your A/C unit should not exceed that rating. However, 13 amps sounds like an odd rating for a household outlet. A bit on the light side. Here in the US we use 15 amps for non heavy duty items such as lights and require 20 amp service for appliances such as A/C, refrigerators, etc... Check your breaker or fuse and see what rating it is set at.
Old 06-15-14, 06:56 AM
Tolyn Ironhand's Avatar
Received 866 Upvotes on 729 Posts
Welcome to the forums!
Please note that this is mostly a US site so the information given here should be verified.
No. The A/C will be fine. It is your wiring that may overheat and start a fire if the circuit is not protected by a fuse.
Follow Norms advice.
Old 06-15-14, 09:20 AM
ray2047's Avatar
General rule is you never change the plug. You change the receptacle. As others have written you should be sure your new receptacle is not rated higher then the amperage of your fuse or breaker or the wiring supplying the receptacle.
