Aquastat wiring and box grounding
Old 06-16-14, 09:14 PM
I have slowly been replacing as much of the original NMD 1 in my house as possible. Over the last 2 nights I have pulled my furnace off the circuit as I knew a lot of the wire was brittle and burned.
It now runs new 14-2 back to a new safety disconnect and new wire back to the main panel.
But as the old wire had no ground, it was never grounded and I am wondering about how to ground the metal box that houses the aquastat.
Does it require the box being connected to the ground?
Do I pigtail a wire to the screw that secures the aquastat to the heating pipes?
The wire on the left was the old power in, on the right, the line to the actual burner was replaced a few years ago according to the past owner and still looks decent.
Old 06-17-14, 05:22 AM
pcboss's Avatar
Received 30 Votes on 26 Posts
I would think the CEC would require the box to be grounded. Can you call your building official or find an on line access to the CEC?
Old 06-17-14, 07:08 AM
The problem here is there a fee for everything, so I have him coming once at the end of the work.
The type of city hall where you pay the parking meters outside and it takes for ever inside city hall and they ticket you the split second the meter expires!
I have posted in boilers and furnaces with hopes the NJ Trooper replies.
Thanks pcboss,
Old 06-17-14, 07:54 AM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
I am wondering why you'd have an aquastat with a forced air furnace. Is the furnace really a boiler?
Old 06-17-14, 10:33 AM
Bad terminology, we call everything that makes heat a furnace.
It is a Viking Junior boiler on a hydronic system.
I was thinking a ground pigtail to the clamp that holds the AC (BX) wire to the box would do the trick but wanted to check before.
Old 06-17-14, 11:22 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
You could use a grounding clip.
