Power to our well
Old 06-18-14, 11:52 AM
A
Power to our well
our well is located 100 feet from the house. The only way to turn the power on and off to the well is by flipping the breaker. Is there a way to wire a on/off switch inside the well house? If so....what kind of switch do you recommend?
Thanks in advance!
Old 06-18-14, 01:37 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
The well house should have a disconnect in it to begin with, so yes, you can install it. Not an off/on switch, but a pull type disconnect, probably $10 at box stores. Oh, welcome to the forums. GE 60-Amp 240-Volt Non-Fuse Metallic AC Disconnect-TFN60RCP at The Home Depot is an example.
Old 06-18-14, 03:09 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The AC pullout is the cheapest option. The are also disconnect switches that look like a breaker inside. A 2 pole switch could also be used.
