Electrical Pop noise
I had a switch that made a pop noise every so often. I switched it out this morning and it appears to be ok now. I was wondering, besides a faulty switch or a loose connection at the switch itself... could this be caused by something else elsewhere in the system? Like a loose connection in another junction box?
The only reason I second guess the situation is because the noisy switch was only a year old and was a spec grade switch with tight connections.
If connections were made on the screws and not in the push backs, it probably was a faulty switch with an arc gap when it was switched on or off. I've got one in my bathroom that does it once a month or so. Scares the crap out of my wife. I'll get around to changing it. Yeah.
Is there a heavy load on the switch? That will make a pretty big arc.
How about a loose connection at the fixture itself?
I ask these things because once I had a very old fluorescent fixture that was causing a similar issue with another switch. When I swapped out the fixture, the problem appeared to go away.
