Grounding lug - which kind to use
Old 06-18-14, 11:33 PM
K
I need to bond the hot tub to steel post; planning to use bare 8 awg copper, drill a hole in the post and attach bonding lug with a screw and terminate bonding wire in the lug. The installation is outside and the bonding is for the hot tub.
Could you please advise which bonding lug to use. Should it be copper or aluminum? Do I need a DB lug?
Old 06-18-14, 11:46 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
I used a copper lay-in lug before.
[ATTACH=CONFIG]33413[/ATTACH]
Old 06-19-14, 07:08 AM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
If the post is round, I would just a pipe ground clamp of the proper size. Easier to install then Justin's.
[ATTACH=CONFIG]33417[/ATTACH]
