Converting outdoor switches to indoor/outdoor 3-way
Old 06-19-14, 12:51 PM
T
All-
I've got two switches on the outside of the house (housed in outdoor-rated boxes mounted on the wall and fed by wall-mounted conduit)- one controls pool lights (2x500W), other controls a single overhead area light (500W). I want to convert them to 3-way with an additional two switches immediately on the inside of the house. So I'll replace the switches outside to 3-way, add in two 3-way switches in the wall on the inside of the house and wire them up.
Question- does the wiring need to be inside conduit to make that 6-8 inch run through the wall? All the connections will be made inside boxes.
Thanks!
Old 06-19-14, 06:39 PM
Received 3,749 Upvotes on 3,362 Posts
No.... not at all.
I'll tell you how I would handle that. You'll need to pull the box from the wall and maybe a pipe strap or two because you are going to need to unscrew a knockout from the back of the weatherproof box and to drill a hole thru the house. I would use a twin romex connector on the back of the weatherproof box. The hole thru the house will need to be large enough to handle a twin connecter. Use two short pieces of 12-3 or 14-3 romex to connect the boxes.
Be sure to silicone the hole around the connector as well as the top and two sides of the weatherproof box to keep water out of the wall.
Old 06-19-14, 08:08 PM
T
PJ- that is fantastic information- appreciate it!
