3 Cables Per Switch
Received 0 Votes
3 Cables Per Switch
Separated from: http://www.doityourself.com/forum/el...ht-switch.html
I have the same problem here but since the solution seems personalized, I could not solve my problem just reading this.
I have 3 cables on each switch. Could you guys help me here?
Thanks
Thanks
Received 0 Votes
I bought a wemo light switch but then I figure that it`s hard to work on a 3-way switch.
I have two switches with 3 cables each. Looks like one of them has the energized cable and the other one goes to the light but I can't figure how to install things to make it work.
Appreciate your help.
Thanks,
Thanks,
You need to explain exactly what you have and what you want to do.
Is there one three way switch at either end in their own box or are there multiple switches in these boxes ?
Is that wemo device designed to work on three way circuits ?
Received 0 Votes
The wemo device has two black wires, a neutral wire and a ground wire.
None of my wall switches have ground wires.
I guess I have one three way switch at either end in their own box.
I have only one switch per box.
I can neutralize one of the switches if necessary.
Is it possible to do?
I'm starting to thinks it's not.
The biggest problem with a replacement switch like that is it requires a ground and neutral. If you don't have both then it won't work for you.
