Voltage Fluctuation
Old 06-22-14, 01:07 PM
A
Voltage Fluctuation
Ive noticed the line voltage in the house has varied at different times. I have found it as low as 115-116, sometimes spot on at 120 and the majority of the time it measures about 122. And it changes from day to day or even time of day.
When I measure the voltage I get the same reading at outlets on either leg of the service. But sometime one leg might be 1 or 2 volts higher than the other.
I know there is a percentage tolerance from the POCO, but I was wondering, is it normal for it to fluctuate like this? Is this something worthy of further investigation?
Old 06-22-14, 01:48 PM
Received 3,881 Upvotes on 3,478 Posts
Sure..... the voltage varies constantly throughout the day. Your voltages are actually very close and are normal.
I'm sure out there you'll see some 110v days when it's hot and everyone's A/C is running.
Old 06-22-14, 01:56 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Yes, it is....and yours is well within spec. I believe the fluctuation can be up to 5%?
Old 06-22-14, 02:11 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Voltage +/- 10% is considered normal.
Old 06-22-14, 03:34 PM
Gunguy45's Avatar
Super Moderator
What am I thinking of? A/C caps maybe?
Old 06-22-14, 03:37 PM
Nah...Some people like to keep it +/-5% for sensitive equipment, but the industry standard is +/-10%. That why 208v equipment will work fine on 240v, and vice versa.
