Guitar Amp Fuse
Old 06-25-14, 06:09 PM
Handyone's Avatar
Guitar Amp Fuse
I have a 1965 Fender Amp.
Back panel calls for 2.5A Slo-Blo Fuse.
I replaced it with a 250Volt 2.5A Fuse (Slo-Blo), that's all I could find.
Is this OK? I don't want any chance of this thing frying.
Thanks.
(And yes, it is loud)
Edit: Also, should I be concerned of why the fuse blew? It hasn't blown a fuse in many years.
Old 06-25-14, 06:39 PM
ray2047's Avatar
It is fine for the fuse to be of a higher voltage. Sometimes fuses just blow from age. The fuse heats and cools expanding and contracting causing metal fatigue over the years.
Old 06-25-14, 10:31 PM
Received 3,976 Upvotes on 3,569 Posts
You may have one or several power supply capacitors that are drying out. They can cause excessive hum and can cause the fuse to blow on turn-on due to lower than normal resistances.
A shorting tube filament can also cause a fuse to blow.
Old 06-26-14, 04:00 AM
R
Received 1 Upvote on 1 Post
A vintage blackface Twin, perhaps? Mmmm!
If you haven't done it recently, change the tubes. And, like PJ said, you need to have that amp looked at for cap issues. You don't want to continue to use it if there is a problem because the transformer could become damaged. Once that happens it's a done deal.
Old 06-26-14, 07:35 AM
Handyone's Avatar
It's Vintage Blackface "Showman" Head with 4 x 12 Cab.
I'll change the tubes, they're expensive, (8 tubes), but it will also improve the sound.
Nothing like new tubes. If it does need capacitors, do they make "vintage" style, (Like Huge Ones)?? Or would it be repaired with modern components??
Thanks
Old 06-26-14, 08:04 AM
Handyone's Avatar
For You Amp Fans, Just a note:
The transformer is important. Fender doesn't have records of serial numbers for early amplifiers. They do have serial numbers of transformers for some reason and this is how you would authenticate the year manufactured.
Old 06-26-14, 09:04 AM
Nice amp.
There were a select few, or now maybe one place that could offer you a replacement or custom wound transformer.
They still make large style electrolytic capacitors.
Old 06-26-14, 09:50 AM
Handyone's Avatar
Thanks Guys,
After 50 years, It could use some maintenance. I wish Cell Phones had 8 tubes, the sound quality would be great.
Old 06-27-14, 04:36 AM
R
Sure, you could get a custom wound replacement transformer, but it wouldn't have the same tone as the 50 year old broken-in original. I would love to have that amp -- I'm playing in a Chicago tribute band.
