Duct Seal Quick Fix
Old 06-26-14, 01:58 PM
A
Duct Seal Quick Fix
Is this a sufficient fix?
AC disconnect. One of the concentric knockouts was slightly bent. There was a bit of a gap where the male adapter for the conduit is attached. I put a bead/worm of GB duct seal around it.
Is this OK or am I setting myself up for water infiltration?
I guess I could have used a reducing washer but did not want to take everything apart.
Old 06-26-14, 02:00 PM
Received 4,051 Upvotes on 3,634 Posts
Where is the knockout on the box ? Top, bottom, sides ?
Old 06-26-14, 02:10 PM
A
1/2" side knockouts with PVC male adapter and locknuts attached.
Old 06-26-14, 02:55 PM
pcboss's Avatar
Received 201 Upvotes on 176 Posts
The KO's on a raintight enclosure are below the level of the electrified parts. Even if water got in it should leak out the bottom.
Old 06-27-14, 04:19 AM
A
I also noticed that THHN was used in the conduit and disconnect. Should wire rated for wet location have been used? And if so, is the use of THHN a looming issue? Theres about 3' worth, in PVC, where it exits the foundation and over to the disconnect.
edit: just noticed a similar spool of southwire #14 I used (same brand as the #10 stranded on the AC) says THHN or THWN. So I am assuming all modern wiring is rated for both?
Old 06-27-14, 05:02 AM
pcboss's Avatar
Most wiring of recent vintage should be dual rated.
