Lights in my bedroom went off, circuit didn't trip, won't reset
Received 0 Votes
Hi all,
I have had a recurring problem in my apartment. I use a portable air conditioner in my bedroom. My wife vacuums my house everyday as I have bad allergies, anyways she occasionally causes the circuit to trip in that room. Today unfortunately for me she did this. The circuit didn't trip this time, and I have tried to reset it but that yielded no results. I then tried to reset each circuit in the breaker box, and still I can't get the lights in my room back up.
I was wondering if any of you guys could help me diagnose, and fix the problem. Thank you in advance.
Attached are pictures of the breaker box. It is a Loadcenter Cat. No. H0M20M100C. The breaker that keeps tripping is the named "general lights" that is on the lower right. All other lights work fine.
If you don't own the apartment for reasons of liability you shouldn't touch the electrical. Call the landlord. http://www.doityourself.com/forum/li...-pictures.html
WARNING!! You should always turn off both the main breaker and the branch circuit breaker before working on the breaker for a branch circuit. I see no main breaker so either you need to find the panel that has it or be extra careful. After the wire is removed you would turn power back on to make your voltage measurement.
Received 0 Votes
So you suggest I turn off the main breaker, then unscrew and remove the circuit breaker, then remove the wire from the breaker and measure the amount of volts? Is there anything I should avoid touching? Thanks for the help. I will check this when I get home.
Edit. this appears to be above your skill level. The panel is too dangerous a place to work if you don't have the knowledge or skills. Call an electrician.
Received 0 Votes
Lol thanks....
I am just trying to diagnose at least so I don't get screwed over. If it hypothetically is a the breaker how much would that cost? (Range??) If it is wiring around what do you guys think I would be looking at?
I will definitely just wait til my next check comes in and give a call to an electrician. I will carefully watch him to maybe learn a thing or two. Thanks again!!!
Received 0 Votes
That breaker sounds like a Sq D Homeline . Should not cost more than less than $ 10 at your local big box store , if it is just a plane single pole 20 or 15 amp circuit breaker .
My bet is it is something other than the CB ? Such as a loose / bad connection at a receptacle ?
When you turn the CB all the way off , as far as the handle will go . Then try to turn it back on . Does ot trip / pop back or not do much of anything ?
God bless
Wyr
God bless
Wyr
