Reconnecting a broken circuit
Old 06-27-14, 07:57 AM
T
I have a shed in the back of my yard, which had been connected to the circuit breaker in the house. We had a pool built last year, and the connection was cut. I want to reconnect, but we also have a detached garage that is in between the house and the shed, and it has unused breakers on it. So I can easily find where the wire connects to the shed, and I thought it would be easiest to run the wire to the box in the garage. I know this is electrical work so all the right warnings need to be given and followed, but I've been reading up on how to do this & it really should not require a professional in my opinion. Does anyone disagree?
A couple questions:
* I can use either 12- or 14-gauge wire, right?
* I need to use outdoor cable and bury it roughly 12 inches underground?
* This shed has two lights and one outlet - I can use a 15-amp circuit, right?
* Anything else I need to know?
Thanks for any advice you can offer!
Old 06-27-14, 08:11 AM
ray2047's Avatar
15 amp breaker for #14 but at only slightly more cost why not a 20a breaker and #12.
12" if GFCI protected and 20 amps or less otherwise 24".
Old 06-27-14, 02:23 PM
T
Thanks for the advice
Thanks Ray, and I will take your advice very seriously about being careful. You got me a little nervous.
