Help - change my motion senser exterior wall light
Old 06-28-14, 12:38 PM
I tried to change my exterior wall light to motion exterior wall light.
However, my exterior wall light only has 2 wires, which are black and yellow.
and the new motion exterior wall light has 3 wires are black, white and yellow.
How do I connect those wires.
So, is black to black, yellow to white, and if I got this right yellow is grounded wire so i don't need to connect.
Thank You
Old 06-28-14, 02:30 PM
Received 3,973 Upvotes on 3,566 Posts
If you only have two wires coming thru the conduit...... the black goes to black. The white goes to yellow. The remaining yellow wire from the light is not ground.... it's an extra switched output that should be capped off.
Old 06-28-14, 02:45 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Like PJ said. Bet it you check the instructions the fixture can control another light if wired properly.
