3-way circuit to a shed sub-panel?
I understand that I have to have a disconnect for circuits in a separate building. Can a disconnect be a 3-way switch?
I want to wire a shed with some devices that I can control from the house or at the shed. Can I install a 3-way switch after the 30A DP breaker in the house and travelers for one of the feeds and then another 3-way before the sub-panel in the shed? I think this would require 5x #10 conductors.
How far down would I have to bury PVC conduit for this run?
Is there a lubricant than can help in pulling wire through PVC?
Thanks for your help.
Usually the disconnect is provided by either using a main breaker panel (the main breaker is used as the disconnect) or by adding a back fed breaker to a main lug panel (but only if a breaker hold down is available). Six circuits or less* no disconnect is needed.
*What constitutes six circuits is open to interpretation. Some say space for no more then six breakers in the panel, others say only six breakers installed meets the requirement even if the panel can hold more.
Thanks CasualJoe.
I am going to use a 15A and a 20A breaker on each phase in the sub-panel in the shed. So there will be four circuits in the shed. The 3-way arrangement is so that I don't have to go back to the house in order to turn on any or all devices on both circuits on the "3-way" phase.
Are you suggesting that I run one sub-panel circuit hot back to a 3-way in the house, then run two travelers back to a 3-way in the garage? This would only give me house-or-shed control of devices on one circuit in the shed, plus I would need to run three additional wires.
What am I missing?
What am I missing?
What am I missing?
or by adding a back fed breaker to a main lug panel.
Other brands may work, but I don't believe the BR from Cutler-Hammer would work in the OP's case.
I would like to have house or shed control for yard lighting and/or for an irrigation pump. I'd also like to have always-on power for working in the shed.
Re 3-way switches and underground wiring, I found a 2008 NEC and have been reading Articles 225 and 300. Would the exception under 225.36 (below) apply to my situation with a shed?
225.30 Number of Supplies. Where more than one building
or other structure is on the same property and under single
management, each additional building or other structure that
is served by a branch circuit or feeder on the load side of the
service disconnecting means shall be supplied by only one
feeder or branch circuit unless permitted in 225.30(A)
through (E). For the purpose of this section, a multiwire
branch circuit shall be considered a single circuit.
225.31 Disconnecting Means. Means shall be provided
for disconnecting all ungrounded conductors that supply or
pass through the building or structure.
225.36 Suitable for Service Equipment. The
disconnecting means specified in 225.31 shall be suitable
for use as service equipment.
Exception: For garages and outbuildings on residential
property, a snap switch or a set of 3-way or 4-way snap
switches shall be permitted as the disconnecting means.
My "Disconnecting Means" would be the four-breaker panel plus the 3-way -- for a total of five handing motions to assure all power is off in the shed. I am a novice when it comes to the NEC, but this seems like it would be allowed. What am I mis-interpreting or overlooking?
Thanks for your patience.
Also, if I am reading Table 300.5 correctly for Column 3, I only need to bury the PVC 18". Is this correct?
Thanks again.
Thanks again.
Joe wrote:
Thanks. Edited my post.
there is no hold down kit available for breakers smaller than 60 amp
