Sanity Check
Sanity Check
Hi All,
I need someone to take a look and tell me if I am nuts... I am popping a fuse and either I fat fingered a connection or I am totally off on my design. Before I go crazy I want to be sure my diagram was sound...then I guess I need to just go through one by one to see where I screwed up.
The current configuration is due to remodeling (and limitations on the wires already in the ceiling) putting in several lights where there was one.
I added a diagram below.
Welcome to the forums!
Your diagram is correct, you made an incorrect splice someplace. I suspect you connected the white in the 3 wire cable to the 2nd 3way to the neutral wires. That is where you should start.
