Upgrade 3-wire receptical to GFCI
Hello - I have some old receptacles wired with 3-wires (red, black, white). On 2 of them the tab on the hot side is broken. On the 3rd receptacle they are actually jumpered. I want to replace them all with Cooper VGF15W-3 GFCI outlets as they are all behind my kitchen counter. How do I connect the new GFCI outlets with this wiring?
Thank you!
Thank you!
two of them the tab on the hot side is broken....
Assumes two circuits on different breakers but would also apply to a half switched receptacle on one breaker.
You will need to only use one hot on the GFI. The neutral will need to be pigtailed where the circuit splits into black and red.
Thank you. After this is done, using 2 GFI's - can you think of any reason why only one would work? I have a feeling that one of the sockets in the original outlet didn't work before, but I attributed it to a bad receptacle.
