correct way to remove a Knob and Tube splice?
I would like to replace a couple of the remaining knob and tube outlets in the front room of my house. Both outlets have wiring spliced onto other K&T lines.
What is the best way to terminate the splice so I can remove the wiring? My understanding is the wires are spliced then soldered. Do I cut the wire that branches off and re-wrap the existing run?
Thanks.
Thanks.
You would need to cut the wires off as close as possible to the splice and then re-tape the splice including the cut wire.
