Wiring in a Divided Attic (part Accessible)
Hello,
I bought a new home in Northern California two years ago. I've been slowly improving the wiring (previous homeowner was a DIYer without a lot of sense), but I've run into a big issue.
The attic (one-story ranch-style home) is divided into two sections by framing and a layer of drywall. The larger section is only accessible via a scuttle hole in the hallway, and a crawl hole in the aforementioned drywall. The smaller section (above a converted garage, hence the wall in the attic) has permanent pull-down stairs and a little storage. The hole between the two is cut in the drywall, which allows one to (just barely) crawl between the two attic sections.
My question: Does the entire attic count as "accessible" because of the pull-down stairs in the smaller section? Do I need to follow wiring codes to protect runs of romex in the entire attic, or just in the "accessible" section? I've been over the code, but I can't find any information about divided attics.
Thanks!
-Nathan
Thanks!
-Nathan
accessible doesn't always mean convenient. In fact you could have blown in insulation covering every box and raceway in the attic (not knob and tube) and it would still be considered accessible.
Thanks for the replies!
I thought the same thing when I started working in the attic. However, that argument doesn't apply to scuttle holes -- those are also "accessible but not convenient" -- and yet those do not require wiring protection (except within 6 ft of the hole).
Is there actual language in the code that covers my situation, or is it going to be 100% up to the discretion of the inspector? Is there a definition of "accessible" in the wiring code?
For what it's worth, I could screw a sheet of drywall or plywood over the horizontal access into the larger attic section, thus making it no longer accessible... maybe?
