Two lights on 3 way switches
I have a driveway light mounted on the garage and porch lights that are wired together to 3 way switches. One of the switches is next to the front door/porch and the other is next to the door leading into the garage.
What I would like to do is separate them (single pole switches). What do I need to connect/disconnect. Which terminals on the 3 way are what? Are all 3 ways wired the same way?
Thanks,
Greg
Thanks,
Greg
Thanks for the reply Ray.
If I were to disconnect the wires from the switch and put wire nuts on them, then energize the circuit and use a voltage tester on the individual wires, would that tell me what I need to know as far as where the power is coming from?
Not sure what you mean by voltage tester. You need to use a multimeter, preferably analog. (A non contact tester won't work.) The power in will usually be a 2-conductor cable (white. black +ground). You need to disconnect the black and measure to neutral. It could be at one of the switches are the light. If you post pictures of the switches and lights pulled out but still connected we may be able to tell you where to check. http://www.doityourself.com/forum/li...-pictures.html
