ac. oven
ac. oven
can ; connect a 220 20 amp. ac unit to an oven? this is in a trailer the ac. is a window shaker. the oven is on twin 50 amp breaker. if o.k. like to know, just trying not to run another wire. all the way on other end. if not so be it.
Well first off you have 240 volts but so is the AC so that is okay. You would need to change the breaker to a 30 amp if the AC's full load amps is really 20 but that seems high for a window unit. Do you really mean it requires a 20 amp circuit? If so a 20 amp breaker.
