Neutral lug kit thread dilemma
Old 07-10-14, 04:46 AM
I've installed a Square D QO 70 amp sub panel off my old Cutler Hammer (CH) and because of the wire is 4awg copper it won't fit into the neutral bar of the CH. I went out and purchased an Eaton neutral lug kit made for both BR and CH, however my CH panel's neutral bar set screws are 5/16"-24 and not the smaller 1/4" that came with the kit. I see myself left with only two options, the first is getting a bolt on lug and a 5/16-24 bolt to attach it or a forked lug that fits into two neutral bar spaces. I can't get a forked lug that is specific for Cutler Hammer CH, but I did find one that fits. I also purchased a bolt on lug and a 5/16-24 bolt. Can someone tell me if one or the other is a better idea and can a zinc /yellow zinc coated bolt be used to bolt on the lug to the neutral bar? Thanks
Old 07-10-14, 04:55 AM
pcboss's Avatar
Received 32 Votes on 27 Posts
Normally #4 is the largest that will fit in the holes in the bus. CH might have different size holes in the bus instead of one size.
Old 07-10-14, 02:30 PM
Hi
Just had the exact problem two days ago.... Except the Sub is a Eaton BR.
I could not find a lug that would fit the CH panel. Found a bolt that would fit but it was too long.
I used two of these (one for ground and one for Neutral) for a #1 AL wire.
Passed inspection last night. Had to get it at a electrical supply store - the ones at the big box didn't handle #1. I think they do handle #4 however.
Old 07-11-14, 02:22 PM
Thanks for the replies. I grabbed a couple different forked lugs and hopefully one will fit. I don't think the neutral bar can accept #4, but I will check again. Sadly the neutral will never carry more than 20-30 amps back, but I didn't want to undersize it.
Old 07-11-14, 06:12 PM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
If you check the fine print on the label inside the panel door, the wire sizes the neutral bar will accept might be mentioned.
