Replacing 15 amp receptacles with 20
NEW QUESTION. I've been having some issues with 15 amp sockets failing in my house, these were all new about 10 years ago, but over the last 5 years I've been having to replace outlets that just went dead, wire is fine outlet is not, no noise no nothing before they go bad, this is bizarre since I've had outlets in houses that were 30 years old and they never went bad. So I decided after looking at outlets and seeing they're made in China and thus probably crap to try a 20 amp outlet and see what happens because they seem a bit more robust in construction.
If I'm not plugging anything into that I wouldn't normally plug into a 15 amp outlet, or overloading it with dozens of extension outlets all plugged into one outlet, and I'm not changing the circuit breaker to a higher amp capability then what harm is there doing that if the circuit breaker will pop should I by chance exceed it's capability?
I also replaced a switch for a garbage disposer with a 20 amp because that original 15 amp switch went bad, and so far no problems for the last 3 years.
I read all the above stuff on this thread but I just don't see how it's a problem doing what I'm doing, but I'm tired of replacing outlets because cheap made in China 15 amp ones are just quitting. I talked to a friend of mine who is a electrician and he saw no problem doing what I'm doing either and that outlets are not made as well as they use to be made and so they will fail from time to time but a 20 amp should last longer. So why all the negatives on this?
Welcome to the forums, froze.
I moved your question into its own thread, you'll get a lot more visibility that way than tacked on to the end of a four year old thread.
Received 38 Upvotes
IF any of the receptacles are on 15 ampere circuits it is a code violation to install 20 ampere receptacles. Rather I would suggest using "specification grade" receptacles.
Most likely the original receptacles were the lowest cost option available when the house was built. Were these original receptacles connected by push-in connections or by the screws, if screws were even an option. In my house the receptacles did not have screws but only push-in connections and I have replaced them.
It truly is amazing..... you buy receptacles from .49 each up to $4-$5 each.
You definitely want to buy spec grade devices like Furd mentioned.
I would say that installing spec grade in a house is way overkill and a waste of money. Commercial grade should be enough and several dollars cheaper.
When I was in my first house even the cheapest receptacles lasted 15 years.
Your friend doesn't sound like a very good electrician if he is encouraging you to violate the National Electric Code.
Same guts in a 15 amp and 20 amp receptacle. Only the slots in the face are different. As Furd wrote just try a better grade.
As long as you have a 20A breaker and wiring capable of 20A, there is nothing wrong with using 20A receptacles.
Perhaps I misread it but I think he was referring to putting 20A outlets on a 15A circuit....
ie:
And why are we even discussing this? Pony up for the 2 dollar outlets and call it a day.
ie:
