220Volt British Electric Iron
Old 07-10-14, 07:07 PM
V
Hello,
I have a British made electric clothes iron that runs 220V AC. I have used it in extensively in the US, on a 3 prong 220V Dryer outlet, with no issues. Problem is I have now moved to a new home that has 4 prong dryer outlets.
The iron has 3 cords (Earth, Neutral & Live). In the past I have connected the Neutral & Live to the "hot pins" in the US 3 prong plugs, and the "Earth" wire was connected to the Ground pin.
I am unsure how to safely connect the three wires (Earth, Neutral, Live") to a 4 prong plug. Will the following arrangement work, and also be safe?
"Neutral Wire" to "Hot pin"
"Live wire" to "Hot Pin"
"Earth wire" to "Ground pin"
"Neutral pin" is left unconnected to any wire.
Thanks in advance for any advice.
Old 07-10-14, 07:52 PM
Received 3,885 Upvotes on 3,482 Posts
Welcome to the forums.
I'm not condoning what you are doing..... just telling you that your connection method is correct.
Old 07-10-14, 08:03 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
You'd be much safer installing a 6-20R (20A 208V or 240V) receptacle and 6-20P plug cap.
Old 07-11-14, 07:04 AM
bigboypete's Avatar
Easy fix. Buy a new iron.
PJMAX- I'm not condoning what you are doing..... just telling you that your connection method is correct.
Don't encourage hacks.
Old 07-11-14, 08:54 AM
V
Thanks. The iron has been extremely useful. I am very reluctant to dispose it off.
Old 07-11-14, 09:05 AM
V
Thanks for your assistance!
Old 07-11-14, 10:08 AM
ray2047's Avatar
Safest way would be a small step up transformer. That way it could be used on 120 volts and the transformer would provide some isolation since you have no way of providing the grounded conductor it was intended to use on 220 in the U.K. I don't know the wattage of the iron but here is an example: Amazon.com: Goldsource STU-1000 Step Up/Down Voltage Transformer Converter - AC 110/220 V - 1000 Watt: Electronics You might be able to build a cheaper one by buying just the transformer used on Ebay.
