Bonding Screw
Old 07-14-14, 04:23 PM
Bonding Screw
Am I correct that since this new box will be our primary panel we are to turn the green bonding screw in clockwise? We have a separate earth ground rod that will connect to the ground strip. I assume Siemens does this in the event someone wants to use the box as a sub panel or main panel. Thanks
Old 07-14-14, 04:33 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
If that panel will have the first means of disconnect after the meter the bond screw is installed.
Old 07-14-14, 04:40 PM
yes, it will be first means of disconnect from the meter. So we will turn the green screw in, thanks.
Old 07-14-14, 08:20 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
No, the GEC from the ground rod connects to the neutral bus. The bonding screw bonds the panel can and ground bar to the grounded neutral.
Old 07-15-14, 05:51 AM
ok, thanks for the input, installing today or tomorrow.
Old 07-15-14, 04:46 PM
Just FYI, new panel in and operational. Prior to install checked with meter and ground/neutral was not bonded, turned screw in slowly while checking with meter and ground and neutral bus now electrically bonded as advertised. thanks to all
Old 07-15-14, 04:49 PM
ray2047's Avatar
Thanks for letting us know the outcome.
