Wires from a small plug-in transformer
Old 07-14-14, 05:25 PM
B
There are two wires coming out of the transformer. One has a stripe and one does not. It is a DC output of 12V. Which one is positive and which one is negative. I have used these transformers to trickle charge small rechargeable batteries before.Just for get which is + or -.
USELESS
Old 07-14-14, 05:42 PM
Received 3,880 Upvotes on 3,477 Posts
There is no set rule. It could be either polarity. Sometimes it's shown on the wall wart.
If not.... you'll need a voltmeter to check.
Old 07-14-14, 08:06 PM
F
You can use a potato if you don't have a meter. How to Use Potato to Test the Polarity of a Battery
