Electrical outlet wiring
Old 07-15-14, 05:57 PM
X
I replaced 2 basement light fixtures with outlets. Each outlet has a plug-in fluorescent fixture attached and an unused receptacle. Both are attached to the same switch. When I first placed the outlets into operation everything worked as expected. Then when I plugged something additional into one of the outlets the light on the other outlet went out. Both outlets have 2 red wires and 1 white. I connected the red wires to the hot side of the outlet on each and the white wire to the neutral side. Trying to figure out what's happening.
Old 07-15-14, 06:11 PM
Received 3,740 Upvotes on 3,356 Posts
Welcome to the forums.
You replaced two basement light fixtures with receptacles.
How did you get red wire.... are these junction boxes connected with conduit ?
It almost sounds like there is an electronic device in the supply line.... like a dimmer.
Old 07-15-14, 06:15 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Did you trip a circuit breaker,?will the circuit work when you remove the newly added load?check for a loose connection in the outlet you were using.
Geo
Old 07-15-14, 08:18 PM
X
I removed the simple fixture and used the wiring that was attached to that. I guess the fixture was hooked up with 1 red and 1 white. I probably uncapped the 2nd red and attached it to the 2nd hot screw. Maybe I have to use only 1 red and cap the other one off.
