Sylvania panel - what breaker types can I use?
Hi, Sylvania panel. What new breakers will work on this panel?
ie. Will this Eaton Cutler-Hammer work?:
Eaton Cutler-Hammer | Plug-In Duplex/Quad Replacement Breaker - 2-1P 15A & 1-2P 40A | Home Depot Canada
Also, what is the meaning of QBH, BQL, BQLT and BQGF?
[ATTACH]35062[/ATTACH
That obsolete panel should be replaced.
That's a GTE/Sylvania. You will likely find a breaker to cram into that dinosaur but it would not be listed to be used with whatever breaker you find. And since that would be a code violation, I don't think anyone here will suggest an alternative for you.
On closer inspection of the picture, it looks like you have a 40 circuit panel that uses bolt-in breakers so that would rule out the C-H BR series. I'd match it up to a Cuter-Hammer Type BAB bolt-in breaker and see if it's the same, I think it will be. The plug-in Quad breaker you linked to definitely will not work. If the Type BAB won't work, Cutler-Hammer also has a Type QBHW that may work.
Bolt on breaker for miniature circuit breaker applications
Just because CH fits doesn't make it right if they are not listed/tested for that panel.
Also is this Sylvania the predescessor to the Zinsco panels? Does it have the same safety issues as Zinsco? If I owned that panel that would be something I would be investigating.
The OP's panelboard is a Sylvania and it takes only bolt-in breakers and it is in Canada. I would also start thinking about replacement, but I don't see it as an emergency.
Could it be a bolt-on Cutler-Hammer CH?
Robot Check
