3-way switch for single pole operation?
In my kitchen we have a series of 3 switches. I wanted to replace them with decora style switches.
The one on the right has me confused.
Its a 3-way switch but the thing is it controls the ceiling fan solely from that one location. It is not like the switch on the left which has to be 3-way as it controls a light from this location and another across the kitchen.
Questions:
Should I replace the switch on the right with another 3-way switch?
Why is it a 3-way switch if its only controlled from that one location?
Here are more images if it helps. It looks like they are looped together.
Questions:
Do you have a switch that doesn't do anything? The reason I ask is that switch was not installed properly because I can see the wires are not wrapped around the screws the correct way. I suspect it is miswired and there is another switch that doesn't work.
chandler & Tolyn Ironhand, there is such a switch that does nothing. It is behind my microwave. I really dont care if that switch works or not since it is not accessible.
CasualJoe, there are wires on both sides.
It looks to me like there is a black wire connected to all three switches. If there is, that is your hot wire and that should be connected to the common (black) screw of the three way. The other two wires are connected to the brass colored screws, they are the travelers. The same wiring will be on the new Decora switch
Chandler, here are the pics of the unknown switch. We thought it would be part of range fan (it appears as though one was present at some point, but isnt now. It doesnt function and is the only such switch in the house.
Tolyn Ironhand, you are correct. There is a black wire going to all 3 switches.
I just wonder why there is a 3-way switch going to a fan controlled from 1 location.
I agree with Pete. Replace it with a three way (wired better, please) and use it. Another scenario is a three way switch got buried on a remodel. Seen that, too.
I agree with Tolyn, the black wire should be placed on the anodized screw.
The green screw is only for grounding. It should only have a bare or green connected to it.
The switch next to the receptacle may be the disconnect for the dishwasher. Try to start the DW with the switch in the off position.
We don't know where these receptacle/switches are located.
We only have close up pictures. If there is a cabinet under this GFCI/switch combo and it is near a sink base, then a garbage disposal may be powered by the switch on half of the receptacle with the other half hot all the time. Do you have any under cabinet lighting?
Lol oh ok. Ya threw me for a second. under the GFCI is a cabinet but this is all the way across the kitchen next to a stove. Thats what led me to believe it was for a fan that may have once been in this thing above the stove (no longer there now).
We do have an inoperable garbage disposal though. No, we do not have any under cabinet lighting.
