GFCI protect both 240V and 120V?
Old 07-28-14, 01:43 AM
H
I have a 60 amp GFCI spa disconnect that also has a slot for a 15 amp branch circuit. Is that automatically GFCI protected?
Old 07-28-14, 06:40 AM
No....you may use a regular breaker and a gfi outlet to protect your circuit
or
a gfi breaker to protect your circuit
Old 07-28-14, 07:18 AM
A
Received 274 Upvotes on 250 Posts
Given a subpanel with a 240 volt double GFCI breaker (such as the 60 amp one you have), that will protect the spa and associated components served by that breaker, both 120 volt and 240 volt equipment.
That double breaker will not provide ground fault protection for equipment served by a breaker in the next slot in the subpanel.
Old 07-28-14, 09:38 AM
H
Many thanks.
Off I go to buy a GFCI. Better than getting fried.
