GFI keep's popping
Old 07-28-14, 11:29 AM
A
GFI keep's poping
A little history on my house.
Double wide built June 1995.
No electrical upgrades.
No garage, pool.
Now the problem Started yesterday 7/26/14 GFI in bathroom when reset it works for about 10 sec. Makes a clicking sound and than pops. I have unplugged everything (I hope) from ALL protected systems.
Not sure where to go now. My experience is Air Craft trouble shooting not house.
Thanks for any advise / help.
Have a great day
and remember to thank a VET.
USN Retired.
Old 07-28-14, 12:29 PM
ray2047's Avatar
Disconnect the cable on the line side and using a multimeter, preferably analog, verify you have ~120 volts. Reconnect the line side and disconnect the cable on the load side and see if it will reset. If not it is probably a bad GFCI.
Old 07-28-14, 02:11 PM
A
It will stay reset if I disconnect the Load Side. And I have 120 V. at the Line Side.
Have disconnected ( one at a time, with the Load side on the GFI connected) all down the line GFI and plain Receptacles. But as long as the Load side is connected it still pop's.
Old 07-28-14, 03:18 PM
you have a small short down the line after the gfi....
or
the gfi is bad.
Old 07-28-14, 03:36 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You don't have a short, but a ground fault. GFCI's don't trip on overload. But I agree the GFCI could be bad if you don't find a fault downstream.
Old 07-28-14, 06:54 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Where are these downline receptacles and additional GFCI receptacles? GFCI receptacles fed from a GFCI protected circuit have been known to cause nuisance trips, is that what you have? Why are these other receptacles GFCI protected, are they in another bathroom or outside?
