No power to apartment after installing new receptacles
Hello
This is my first post...new to this forum...
I am currently experiencing a problem in an apartment. I replaced all the switches without issue but the receptacles are giving me problems...
I broke the tab on the receptacles and installed them how they were wired. However, I backwired the receptacles without going around the screws first...
Bottom line is there is no power in apartment anymore even after confirming the shut off in the hallway is Ok.
I went around to check connections, push wires in further, harder, etc. but nothing and I am out of ideas here...
Any help would be appreciated, thanks...
Welcome to the forums.
You broke tabs from the receptacles. That would suggest that the receptacles are switched from a wall switch(s).... is that correct ?
We don't encourage using the "push in the back" wire connectors as those connections have shown that they don't have long term reliability. We encourage the use of the screw terminals.
Were the receptacles live before you started the device replacement ?
What tabs did you break off
Brass side?
Silver side?
How many per room?
How many receptacles total?
Befor this did the switches work lights in the ceiling?
Or what?
Brass side?
Silver side?
How many per room?
Or what?
Hello
Yes, they were live, working...regretting not just cleaning them now...
I didn't brake the tabs because of any switch connection consideration...I read a lot places saying breaking the tabs is what worked for them and I don't believe they were discussing outlets connected to switches, specifically...am I lost?
The wires may not have been perfect but not terrible. Maybe a little scratched but not knicked... Do the wires have to be perfect when backwiring?
I'm a DIYer, eh!
" Were the receptacles live before you started the device replacement ?"
I thought this meant working? I did not work live if that's what you asked...of course not
Hey John
Answering your question will reveal how much I screwed up...thing is...I had all well wired initially.
I am figuring it out right now, actually...
The questions in your post helped, John!
No two hots on one side... It seems I need to break the tab on a split only where there's a red/extra wire?
In between rooms there are receptacles with loops around both top screws and connections on the bottom screws...
Do tabs need to broken on the hot side in that situation?
in between rooms there are receptacles with loops around both top screws and connections on the bottom screws
Leave the black and red....not jumped out until the end
----------in between rooms there are receptacles with loops around both top screws and connections on the bottom screws...-----------
Do you have 3 cables....3 black wires and 3 white wires...........if so ...tie all 3 blacks together under a wirenut with a pigtail to the outlet.
Tie the 3 whites under a wirenut with a pigtail to outlet.
The pigtail can also jump between the screws
You do not want 2 wires under 1 screw.it will not hold up
I think I figured it out...
I'm confident here is one tab I have to break out of the 15 or so receptacles. I confirmed the known one in my apartment...
Thing is...it's not "switched," it has a red and is the receptacle closest to the panel, oven, range...
I think I got this
I think I got this
Just a reminder: You should not be doing this work. it is an apartment. If you rent the owner should do the work by contracting with a licensed electrician. If you own it given your limited knowledge for the sake of liability and potential danger to other tenants you should hire a licensed electrician. Please don't take the responsibility for others safety in your untrained hands. You may think you have it fixed but call a licensed electrician to have everything checked.
