dusk till dawn hack. on the right track?
Old 07-29-14, 07:05 AM
F
Received 2 Upvotes on 2 Posts
hi all. i'm dismayed by the cost of dusk till dawn fixtures, so i thought of a way to bypass those fixtures and install a series of outdoor lights that will turn on and shut off whenever i want them to automatically.
i'd like to poll you guys on this idea - is the idea (see diagram) kosher? have i forgotten something? is there something unsafe about this approach?
the idea is this (this all takes place in the basement):
1. install a new 15a breaker to my main panel.
2. run romex from the breaker to a nearby junction box with a gfci outlet.
3. connect a digital timer to the outlet (e.g. Titan Controls 734112 Apollo 7 24-Hour Digital Timer, 120-volt).
4. connect a 3-prong pigtail to the digital timer (e.g. 3-prong pigtail).
5. in another junction box, join the open end of the pigtail to romex.
6. run romex from last junction box to a series of outdoor lights.
And just like that, for less than $40, i've got as many exterior lights as i want turning on and off at specific times.
thanks for your input!
Old 07-29-14, 08:24 AM
GE makes a digital timer that does the same thing but can be wired in place of a light switch, which eliminates the un-kosher method of back-feeding a branch with a plug-in device and pigtail cable.
Weekly 7-Day Manual Timer Wall Switch - #M7724 | LampsPlus.com
Old 07-29-14, 08:40 AM
F
MATT - thanks!! i used to think i was a pretty savvy internet searcher... can't explain how i wasn't able to find this before you pointed it out. seems obvious in retrospect that this product exists to do exactly what i had in mind. gonna go with this one, though that i can buy through amazon prime.
Old 07-29-14, 10:34 AM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
There are hard wired digital timers available at the big box stores for less than $20.
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
There are a number of options all available through Amazon if that's where you prefer to buy.
http://www.amazon.com/s/?ie=UTF8&key...l_6oc8r38ybm_b
