Wire type ok inside conduit?
Old 07-31-14, 05:30 PM
P
Hi all. I ran 2" conduit to make it easy for me to snake wire through. I pulled wire through then realized I didn't confirm it's the right type. It says its water resistant, and it's the 3 wire in sheath type.
I running it to pond area underground in conduit.
Will power an external pump 125 volt 1.8 amps
40 watt uv light
X-mas lights or LEDs around pond
Every couple weeks I'll hook up a 1hp spa blower to clean filter
Wire type
CAROL 3/C 12 AWG (3.31 mm2) 90 degrees (UL) SJ OR WATER RESISTANT 300 volt RohS
Old 07-31-14, 06:18 PM
ray2047's Avatar
That is not wire. That is cable. Best practice is to run wire not cable in conduit. Service cable such as you have is not suitable for use as permanent wiring. It is intended for use as cords on equipment. You need #12 THWN (one black, one white, one green) or 12-2 UF-b if you use cable. Conduit needs not be larger than 1" for UF or ½" for THWN individual conductors.
Above assumes a single pole 20 amp breaker and conduit buried at least 18".
Old 08-02-14, 04:48 PM
P
Ok thanks. Would it hurt to use it for awhile until I get the right stuff, instead a cord across lawn.
So basically even cable is ok to use, but needs to say UF? Is UF material stronger?
Thanks
Old 08-02-14, 05:35 PM
ray2047's Avatar
You should always use the correct materials. Not stronger but designed for that purpose. However as I wrote best practice is to not use cable. Use THWN individual wires.
Old 08-02-14, 06:29 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
UF-B cable is for outside and direct burial use. Rule-Of-Thumb: Never pull UF-B cable into conduit.
Old 08-02-14, 07:20 PM
Tolyn Ironhand's Avatar
Received 784 Upvotes on 664 Posts
That is not even cable, that is SJ cord.
For PVC conduit I do not recommend anything smaller then 3/4"
