Ceiling fan hookup trips breaker
Old 08-01-14, 06:41 PM
H
I just installed a ceiling fan in place of just a light fixture. There are two switches on the wall. I did the proper wiring (to my knowledge) but everytime I click the switch for the fan, the breaker trips. When I turn the breaker back on and flip the light switch, it works. But when I flip the other switch, it gets tripped again.
Any ideas what the problem could be?
Thank you!
Old 08-01-14, 06:55 PM
G
Received 2 Upvotes on 2 Posts
First, welcome top the forums.
Please do not post the same problem in multiple areas.
It certainly sounds like it is not wired properly, but more information is needed.
Did both switches operate the ceiling light? What make and model fan? What color wires from old wiring and what color wires from the fan?
ray2047's Avatar
Not without a lot more information. Does power come in at the switch or the fan? How many two conductor cables (black and white) and how many 3-conductor cables (white, black, red) at the switch. Same info for the ceiling.
Best guess is your connecting both sides of the power in cable to the switch.
Please do not post duplicate threads. Your other thread has been deleted.
Old 08-01-14, 07:19 PM
H
Sorry about the duplicate posts.
Here is how I wired it:
Ceiling White to Fan White (Neutral)
Ceiling Pink (Red) to Fan Blue (Light)
Ceiling Grey (Black) to Fan Black (Fan)
Ceiling Bare Copper to Fan Green (Ground)
Light switch on the wall works fine. Ceiling fan craps it out.
Is it possible to have a fan have TOO much power for the outlet?
Old 08-01-14, 07:48 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Why were there two switches on the wall if there was just one light fixture? Did the second switch ever work properly before?
Old 08-01-14, 07:59 PM
H
I'm not sure if it ever worked. When we moved in, there was only a light fixture and we just now wanted to replace them with fans and lights.
I should note that another outlet within the room that I plugged a vacuum into also gets tripped when I turn the vacuum on.
I'm stumped.
Old 08-01-14, 08:14 PM
CasualJoe's Avatar
Most likely the second switch was for that receptacle. You need to pull the two switches from the box and describe all wires and connections you find. DO NOT remove the wires from the switches just yet. You'll also need a meter to do some tersting, NOT a non-contact tester.
Old 08-01-14, 08:17 PM
ray2047's Avatar
So it is most likely the switch box so we need to know the wiring there.
Old 08-01-14, 08:33 PM
H
When I remove the wall switch, I see the two boxes. One has a pink/red wire coming out of the top portion. The other has a gray wire coming out of the top. Both boxes have black wires coming out of the bottom portion. I also see whites/bare coppers all in there. Does that help?
Old 08-01-14, 08:37 PM
ray2047's Avatar
Could you post pictures with the switches pulled out so we can see all the wires and connections? http://www.doityourself.com/forum/li...-pictures.html
Both boxes have black wires coming out of the bottom portion.What are the boxes you write about. Do you mean the switches or is there two separate switch boxes.
Did you change any of the wiring in the switch box?
What I would expect to see there is one 2-conductor cable and one 3-conductor cable.
  • All whites connected to each other and nothing else.
  • Two pigtails to the black of the 2-conductor cable.
  • One pigtail to each switch.
  • Red of the 3-conductor cable to the other screw of one switch.
  • 3-conductor black to the other switch.
Or is this conduit?
